100hp merc question
mphy98
so I finally got the cover and tested the compression on the 1991 motor. No compression on the top cylinder. I would like to take the cylinder head cover off and take a look. I was told that there is no conventional head but it looks like one to me. spark plugs come out and I believe if I take out the "head bolts" then I should be able to see inside the cylinders and see whats up. Am I wrong?
carholme
Re: 100hp merc question
mphy98;
Do you have a manual? If not send us the s/n of your engine and I'll see if i can get you one to do the job. As well we can give you the parts listing for the head gaskets and any other parts you might need.
Gerry
mphy98
serial number 0d0z8202 thank you.
