1100 zxi electrical issues
DAVIDBENNER
I have a kawasaki 1100 zxi and have power to the lights on the gauges but no spark to anything else , where should I start
Rob454
Re: 1100 zxi electrical issues
Does the ski turn over? make sure the lanyard is on correctly the on switch is on for the power and that the start button works. You will need a electric multi meter. You may have a bad starter solenoid that doesnt allow you to start the ski. You can jumper across the terminals with a screwdriver to see if the boat turns over. If it does then you just have a bad solenoid.<br />Rob<br />ss454454@socal.rr.com
