coachbrent
- Feb 26, 2011
- 6
I bought a boat with an Evinrude 110hp that was supposed to have been rebuilt 2 years ago. I doubt it because one of the spark plugs was broken off. The boat was then stored and not run. I took the heads off without too much trouble, only broke 4 bolts. It looks as if the motor cover was not on the motor much water has gotten into the cylinders. One had yellow foamy stuff in it. The others had dirt and trash in them. The space between the cylinder and the outside of the head had junk in it, looks like it was run in salt water and never cleaned. The wiring needs some work also. I am mechanically inclined and don't mind getting dirty doing the work but not sure if I should pay someone to do it. Should I rebuild it or chalk it up to leason learned?
