Re: 112SPL engine Re-wire????
OBJ,<br /><br />I will provide the Model # later this evening once I return home.<br /><br />The reason for the re-wire is a recommendation from my mechanic. He indicated that the engine may have been submerged and the wiring may soon fail. The only indication of electrical problems are with the trim/tilt.<br /><br />Last fall, the trim started to act up, where it would work for a few minutes, then stop working. When I activated the engine cowling switch, I could hear clicking in the relay box, but the engine would not trim up or down. Some tapping on the relays and internal wiring resolved the problem for a few intermittent attempts, however the trim did not work as of last evening. The pump/motor seems to work fine when I provide power directly. I bought replacement relays today and will try again tonight. If the new relays do not resolve the issue, then I figure it must be a wiring fault. Would you agree? What do you suggest for correcting this issue?<br /><br />Other than that, the engine was running great the end of last season, however when I pulled it from the water, the engine alarm sounded (?). I'm not sure why, as I do not have a systems check gauge on the boat. Is there a way to determine why the engine alarm sounded, if I do not have a systems check gauge? I was thinking if the alarm goes off, I could determine which component of the system check gauge was receiving power by connecting a volt meter directly to the deutch connector pins. Does this make sense?
