Daniel Caldwell
- Jul 16, 2008
- 2
I have a problem with yamaha they force you to go to a outboard shop
to do simple jobs my trim is stuck in the up it will not retract and to open up
the trim cylinder you need a tool that should be 10 bucks.i tried checking fluid level and adding weight to lower unit when some held the down botton
it did not help. the tilt tube nees replacing to remove steering rod and the trim needs to be down
