I found the problem with my 78 model 1150 merc stalling at W.O.T. it there was a clamp missing on the fuel line, from the quick connect to the fuel pump. I found it as I was removing the pump to rebuild it. I must still have an air leak somewhere because it still acts like the motor funs out of gas, if you give the ball a squeeze or two it picks up and runs fine.<br />I want to know what the max R.P.M. for this motor is. It's on a 18' Baja, open bow, and we have it loaded pretty heavy. I get 4500 on the tach with a top speed of 34 M.P.H. <br />Does this seem right or do I need to look at changeing props?
