Re: 115hp six mercury airfilter question
These motors are very reliable, and have lots of low end grunt <br />If you take car of it, you will give it to your grandkids. <br /><br />But
<br /><br />There is a few things you should know about them to keep them running.<br /><br />1. they hate bad fuel. Use FRESH premium BRAND NAME fuel only. If you dont your motor will suffer from mechanical failure
fast. Believe me I know from experience. <br /><br />2. Keep the fuel pump in top shape, this will keep the pistons from staving for fuel and burning the top of the pistons. It only takes a few seconds for it to happen, but you can prevent it for about 10 bucks and 10 minutes work. <br /><br />3. Consider jetting the top Carburetor. The top piston is a little bit vulnerable to running lean. If you jet it (parts are cheap and available at your Merc dealer) <br /><br />4. Change your plugs annually. Preferably at the beginning of the year. Its just one of those things.<br /><br />5. Run a small amount of marine two stroke decarbonizer in the tank every once in a while, just to keep the inside of the motor happy. NEVER USE AUTOMOTIVE CLEANERS OF ANY TYPE. <br /><br />6. If you are premixing your gas/oil mix, do not add extra oil for good measure, it will gum up the motor. 50-1 mix is good for most applications, 45-1 is as oily as you want to get it<br /><br />Also just bear in mind these motors tend to be a little Thirsty, but not much more than other Outboards of similar years/power. <br /><br />If you do a little research youll find these motor where called the tower of power and for good reason. <br /><br />Hope this helps
