Ok I've seen a few topics discussing this but no one seems to have a setup like mine. I have 2 red wires and 2 black wires running from the batteries in the back to the front of the boat. Those 4 wires are labeled battery 1 and battery 2 and are hooked up to a rectangular board in front which connect when the 4 prong trolling motor plug is plugged in and from the trolling motor wire which goes to the foot pedal there is a toggle switch on the side of the foot pedal with 3 settings 12v, Off, and 24v. Now that I've described my setup .....here's the problem. When I set that toggle switch on the side of the foot pedal to 12v....it runs, but when I set it to 24v it no longer runs. Now the cables run from the front to the back of the boat and are labeled. Battery 1 has battery 1 red cable to positive and battery 1 black cable to negative....and battery 2 red cable is on battery 2 positive and battery 2 black cable is on negative of battery 2. A lot of people on here seem to have a 3 prong connection so I'm assuming my wiring is likely different. Now.....I really don't even care for the being able to select between 12v and 24v mode. So I'm wondering how to wire mine for 24v mode while leaving the selector on the foot pedal in 12v mode since I'm getting nothing when I set it to 24v mode. Oh and the battery 2 cables are the ones that seem to be live still and work in 12v mode. When I try connecting the battery 1 cables and setting it to 12v mode or 24v mode....I get nothing. Assuming a ground when bad up front in the plug or something is wrong with the selector itself.
