prescott_anthony
- Nov 29, 2016
- 29
12' Fiberglass Boat Restoration - Newbie in Need of Advice
Hello Everyone,
My name is Anthony and I am an expat who stayed in Germany after leaving the military. I am also an extreme fishaholic. I recently purchased an old 12' fiberglass boat which I have pulled into the shop with the intention of fully restoring it. The boat had some fiberglass damage to the bottom of the hull (mainly just rot and damage from being dragged around). My buddy removed the damaged portions and patched the hull up pretty well. I am now sanding the hull in preparation for primer and paint.
At the bow of there is a small door that opens to a storage area inside the bow. I currently have the boat sitting on saw horses with the hull facing upwards. After sanding most of the hull I was underneath the boat just checking out that cavity in the bow and noticed that on some portions of the bow that I have sanded I can see light coming through the fiberglass patchwork that my buddy did. There is no old paint or primer on that portion of the bow any longer and I am wondering my seeing this light is simply the refractive properties of the fiberglass or do I need to get a fiberglass repair kit and put more layers on? On the portions of the hull where the fiberglass was not previously repaired I do not see light coming through but of course there is still old paint and primer there so I wouldn't expect to see light leaking through.
On there areas where I do see light the boat still feels and sounds solid so I am just not sure whether or not I should be worried at this point.
Pictures attached.
Thank you all in advance for any help you may be able to provide!
Hello Everyone,
Pictures attached.
