12 ft aluminium boat Wood Motor Mount Replacement
sasmit8
I am replacing the Plywood Motor Mount Pads on a 12ft. Aluminium Boat.I Have the new Pads all cut out. The inner and outer boards are held together with 8 thru-hull bolts.
I have 2 questions
1. What should I use to seal out water Silicon?
2. What would the best Bolts to use : Steel--Stainless -- Brass--??
Thank you for any help you can give.
new_boater
Re: 12 ft aluminium boat Wood Motor Mount Replacement
seal with 3M4200 and use stainless steel
sasmit8
Thank you for the reply
Thats the way I will go;)
Bob_VT
You need to seal the plywood on ALL edges and surfaces. The replacement plywood will be short lived if you do not seal it up. Yup stainless bolts, nuts and washers along with 3m 4200.....
Good luck!
sasmit8
Thanks to NewBoater & Bob VT
for the helpful info:cool:
