I have an older boat with older MG trolling 42 lb thrust. I have 2 sets of pos/neg wires going to battery compartment. The motor has a 12 v and 24 volt switch-3 prongs. I was running the motor for about 2 weeks running 24 volts and running a pos and neg to each battery with no jumper cable between the 2 batteries. Motor ran fast and good and then started blowing fuses after 2 weeks. I fiddled with the outlet and now it runs off 1 battery only and with the motor switched to 24 v only but not very fast. When I go back to adding the second battery it blows the fuse on this one but still runs off the other one but only at a slow speed. I don't see any probs/connections with the wiring. With 2 sets of pos/neg wires am I set up for 24 volts? I must have more than an improper hook up just needing some guidance on which way to go. Any help would be greatly appreciated. Thanks.
