Re: 120 hp Force impeller
easy job.disconnect the shift rod pin, ;remove the bolt's
remember the one under the tab,mark the tab,has to go back the same way.drop the unit,there is a rubber bushing on top of the shaft,that may stay up or fall when unit is remove.remove the impeller cover there is a key way on the shaft.replace impeller fin's with the same direction as old one.it really not that hard .when reinstalling the unit you may have to drop the shift rod into gear so that you can turn the prop,to get the shaft spline to line up.engine should be raised to up position.the hardest job it getting the unit back up.don't force anything together when reinstalling the unit.i mean like drawing on bolt.
