120hp johnson v4 93 need manual
_mako_20
Water pump needs to be replaced just a little water comes out and some water is coming out right above the jonit of the lower unit.
aanda6
Re: 120hp johnson v4 93 need manual
Hi Mako, welco eto the forum. We will get great advice hear. Water pump is very east to replace but definately get a manual.searh e-bay or online sotres. will make life easier.
DHPMARINE
I would try to get a factory manual from a dealer.<br /><br />DHP
OBJ
Welcome to the forums mako!<br /><br />When you say just a little water comes out....from where? The tell tale or the relief ports on the midsection? If it's from the tell tale, shove a piece of wire up into it and see if that helps.<br /><br />If your seeing water from the mating joint of the lower unit and midsection....your probably running on muffs or motor flushers. This is common and nothing to be concerned about as there is no gasket between the midsection and lower unit and when using muffs, your pressurizing the water intake...water will come out somewhere.....<br /><br />Some basic questions....how long has it been since the pump was changed out? Is the engine overheating?<br /><br />Good idea for a manual, preferably on OEM manual. You can get reprints from Ken Cook Co., marine.com or the outboardwizard....all have sites, just do a search or google them up.<br /><br />Keep us posted on progress or if you have any other questions....Thanks!
MCM
Mako,<br /><br />Located this one on Ebay, Click here, or you could also try KenCook.com or MarineEngine.com as well as an OMC dealer.
_mako_20
I just got the boat and got the motor runing today its pited at that joint were you say there is no seal. buy the exhaust.the small hole in the front water is coming out there to.oil when i put the motor up. i just let it run a little and it did not get hot
_mako_20
A little bit of water is coming out the from under the motor where its should.
