Re: 125 Force Engine with water in case. Help
Do use new VENT/FILL screw gaskets each time you open them up. They are cheap (abt 5 for 2 buks)--And Do try draining and refilling.<br />Take it out for the day, and recheck it when you get back home..Any water at all, and you have a bad seal or seals. <br />The way to find out WHICH seal or seals before tear-down,is to charge the lower unit with about 10LBs (no higher)of air pressure, and submerging it.<br />If bubbles come from the prop area, you have a bad propshaft seal,and won't need to remove the L/U to repair...If you get bubbles out of the water intake, you have a bad driveshaft,shift shaft, or water pump housing seal, and you will need to remove the L/U to repair.And if so, you may as well get an impeller,and kill to birds with one rock.
