CoastGuardCobia
- Apr 12, 2013
- 3
Hello everyone, I am once again stuck scratching my head with my 125 Force. I have replaced carbs, water pump, thermostat, plugs, and just recently starter and battery. My issue is the motor will barely turn over even with new starter and good battery. I have tested battery just ensure it was not just a bad battery I bought by chance. It has correct cranking amps. I have cleaned all connections, grounds, ignition switch connections. Also, I have attempted to bypass ignition switch by jumping the solenoid. It had same issue either way. I took out plugs and it turned over like a champ.
I am out of ideas. It was just running great a week ago. It fired right up after I replaced water pump. It was cooling and pumping like a champ. Then it flooded out at the boat ramp and has not been able to crank ever sense. I am just hoping that I am over looking something. Is it possible the is a rod stuck? Any help would be much appreciated! Thanks everyone!
