125 force staying at high idle
chauncey
When I throttle down my engine it will stay at a high idle (1500 rpm) unless I hand turn the throttle tower back then it will idle @1100 in neutral or 800 in gear. Any suggestions, does something need lube, adjustment or am I missing a return spring?
jerryjerry05
Re: 125 force staying at high idle
No springs.Food's probably right.
Figure out the throttle cable.Unhook it and adjust the connector pulling the tension back to the rear.Just take it apart and mess with it:)
