Re: 125 force
Yes, it is newer design. It will work. The original gasket was a throwback from when the engines were Chrysler. The heads at that time had jackets cast around the sides of the combustion chambers and a single tube running down the back of the head so the perforations in the gasket were necessary. Your head has a completely enclosed jacket on the back and no cast in cooling around the perimeter of the combustion chambers. The perforations are not necessary.
There is a sticky FAQs at the top of the forum on replacing an impeller. Figure around an hour's time and only hand tools.
If you have an inch pound torque wrench, head bolts are tightened to 225 inch pounds in a spiral pattern working outward from the center. Do it in about 2-3 steps starting with all bolts at 125 inch pounds and working up to 225.
Since it is a new headgasket, after running the engine for about an hour and letting it cool, re-torque the head bolts. You will find that the heat will compress the gasket more and you will be able to get around an additional 1/4 to 1/2 turn to reach 225.
