Hey guys, quick question. I have a 1972 125hp johnson, I threw carb kits on both carbs the other day and popped them back on the engine. I started the engine and it fired up and idled beautifully again, the only thing is it was running hot. I had the muffs on it and there was water peeing out the usual spots, as well as the two exhaust ports on the back which I never have observed before,but the water was hot, then I felt the cylender heads and they started to get quite warm then hot at last. All this took place in about 5 min after starting it, so my questions are, where do I start looking. I don't know if I should buy an impeller kit and a new thermostat or what. What should I start looking for. thanks alot.
