Re: 13 ft boston whaler
Unless your towing a very small person and you keep the weight in the boat as light as possible, you may be able to tow someone on two skies. The wakeboard will be a challenge to not drowned the person while trying to pull them up. Also, the weight and shallow draft of the BW will allow the skiier/wakeboarder to pull the back of the boat around when doing tricks or cutting back on a turn. I use to run a 16' trihull with a 70 Johnson and I couldn't pull up a person on single ski but could get them up with two skies and then let them drop one and continue.
