Not much a boater here. I few weeks ago I found this lil whaler 1964 and it had a yamaha C40 20inch shaft. 2 weeks after buying it the rod went through the case. 2 questions--could the longer shaft had been the reason for the engine failure?<br /><br />More importantly, I have a great deal on another yamaha 40 20 inch shaft. Does the extra 50 lbs really make that much different (tilt, trim, battery)? ANd can you recommend a very simple jack plate?<br /><br />Thank You<br />Skipper of The Perfect Pint
