13 x 19 on 3.0l merc
snake91876
i found a good deal on a 13 x 19 aluminum prop. i currently have an unknown diameter 17p prop on heavier 18 ft bowrider with a 3.0l 135hp all are 1987 models. the boat turns 5200 rpm at 32 mph which i know is reving the crap out of it. i dont know if i can run this 13 x 19 what will it do for me.
steelespike
Re: 13 x 19 on 3.0l merc
A 13 X 19 should put you about 4,800 with a little more speed and less hole shot.I'm guessing rpm range is 4600 to 4,800 but I would keep it at 4,600.Of course you could change to the 17 for skiing just don't over rev.
You can figure about 200rpm change for each inch of pitch change.
Ayuh,..... My Guess is,.. That's a prop for a mid-sized Outboard.....
It probably has a 4" diameter barrel,...
It'll slide onto the propshaft, but the body will be Too Small,+ Ventilate Terribly....
Most I/O props are larger, like the Large case Outboards,+ Usually are in the 14" diameter neighborhood....
snake91876
i think it has a 4 1/4 inch barrell will this still be too small
