14 1/2 x 19
joey nathan
What's wrong with this photo?
Prop is for a Mercruiser 120 I/L 4 1R sterndrive. Thrust washer is on the drive-shaft and I have the nut.
Seems fairly obvious that a couple things may be missing here. I realize I'll have to have the prop itself reconditioned, but can I order whatever it is that's missing?
500dollar744ti
Re: 14 1/2 x 19
rubber hub is missing. that prop looks pretty beat up, you might want to look into another one and keep that as a spare.
you can get a new aluminum prop for cheap, if it was stainless i would say go for re-conditioning.
Re: 14 1/2 x 19
Ayuh,.... That's 1 of those newer props that uses a plastic hub kit,...
Yer missin' the big black plastic piece....
jestor68
Re: 14 1/2 x 19
That prop is trashed. I wouldn't bother with it.
If you visit the iboats prop section, you can order a spanking new Solas Rubex 19" for just $120.98(less than the Merc prop). It will come with ALL the hardware(the hub kit) needed for installation.
You're going to need to replace that junked prop anyway; you might as well get the best for less. :)
