Re: 14' Lund deck replacement
[DOH!!
Answered in the next post by BONZ_D. I should'a querried "deck" instead of "floor". I'll figure out the foam question when I remove the DECK. PICS:
Lund S14 DLX In-progress]
So, what were the results of the work of Bonz_D and Marquette? Pics and a brief description of what you found would be great.
(There are no other related posts.)
I have a '95 Lund Rebel 16' tiller steer. It has 50 aluminum rivets holding the carpet-covered plywood floor to aluminum stringers. The boat leaks, and has a soft spot in one corner of the floor. I could live with either, but not both, so I may pull the floor. Some of the leaks are due to pin holes, probably generated from salt water left standing in the bilge or from wet bunks underneath. I put 5" of water in the boat
, and could only find one small pinhole dripping water. I could not find the other leaks. The "fill with water" method did not work for me on another aluminum Lund for finding leaks. Sealing with Gluvit on the inside hull (and bucking/replacing a few rivets) will likely solve the problem. Pulling floor and foam will be necessary for the leak stop process.
Thank you, Marquette, for the post on which floor rivets to use, and where to find them.
Rivets
Questions:
1)
Is there room for an under-floor fuel tank, say about 6 gallons?
My Lund has a small hatch that looks like it is supposed to provide access to a fuel tank top or electrical connections.
2)
Is it possible to re-use the foam? If you removed foam, were the chunks destroyed?
I would prefer not to use pour-in foam, either "stuck" to the hull or free-floated with plastic bags. I will likely spill fuel at some point, and don't want to use "pink" styrofoam. Thus, could I use the original foam, just put it back and let it free-float?
