Re: 140 h.p. compression???
Welcome to iboats.
The first thing I would do is stop writing help, help, help... We all are here to both give and get advise. No need to beat a dead horse.
Your compression is not bad at all. If the motor has sat for a bit you can get a goofy reading, also it can be
effected by how you do the test.
I would run the engine for a few days and see, then retest it. If its the same or still has a bit more cylinder difference that you like to see, try a de-carb (run sea-foam through it) and that may help.
Your best bet is not to over react.
Also you can read
this link and
this link from help.
