I have overhauled the tilt trim rods on a '79 Johnson 140 that had been sitting for several years. The oil seals on the pistons were completely destroyed. I have followed the fill procedure and the tilt piston works great. It raises and lowers the motor. The problem is in the trim rods. When I start to lower the tilt, the port side trim rod immediately retracts. When the motor is tilted down to the rods, then the starboard rod will not retract. When I tilt the motor up, the retracted rod extends and then the motor tilts like it is supposed to. What is making the one rod retract early? Is there something else I need to bleed? Why won't the other rod retract? I'm totally confused here. Thanks for your help.
When I filled the reservoir I made sure that the tilt cylinder and both trim rods were fully extended. I bled the cylinder several times and continued to top off the reservoir. Don't know what else to do.
