15.6 ft flat bottom tinny new restoration
jspano
Just picked up a new little project (like the title says). I will post pics when I get it home.
Doesn't need a lot boat wise motors both the 25 hp and the trolling are evinrudes are old but all were cheaply priced.
my question is the wood transom on the inside and outside are bad. the inside has 2 alum boxes in the corners ( I think are filled with foam).
is there a trick to getting the inside transom board out and then replaced with a new one. Yes pics will follow.
jspano
trying to upload some pics keep getting error msg.
jspano
don't know why I can't upload phots. I tried from my computer and even tried links from photobucket???
jbcurt00
Looks like you need to remove the transom corner caps and the aluminum channel along the top of the transom wood to get the old out.
You can post more then 1 pix per reply
g0nef1sshn
Just make sure you dont use and remove all PT wood. And take your time removing the cap so you dont break it taking it off so you can reuse it!
jspano
the end cap appears to be welded on. ???
jspano
have another problem(besides posting pics) the tag states that it is a 1983 evinrude 25hp (no spark) but when I try to look up the coils they do not look like what's on the engine???
g0nef1sshn
If they are welded on, grind them off. Then without being actually there to see them, I would think I would drill new holes to rivet or screw them back on. Unless you know an aluminum welder of course.
jspano
thanks, any way to tell the yr on this mtr it is not looking like the 1983 parts breakdown
g0nef1sshn
A few pics of the engine and cowling in the outboard section might be able to help you narrow the year question down.
jspano
right.jpg~c100
left.jpg~c100
back.jpg~c100
back.jpg~c100
back.jpg~c100
