zaroba
- Jun 9, 2008
- 84
while helping my aunt and her husband clean out my grandfathers old house, I claimed the 1953 Evinrude Super Fastwin that he had in his garage. he had used it on his wooden boat long before i was even born. The rotted wooden boat was scrapped long ago, and the outboard had been put in the garage, where it sat on its stand for the past 30+ years. overall, its in excellent condition. no rust or other corrosion, all the levers etc work fine, engine can be spun and still has excellent compression.
now i am trying to get it running again.
replaced the lower unit oil, put it in a bucket of water, and put a gallon of gas into its tank. then, following the directions on a sticker on the motors crown, i primed it, put it in neutral, set the speed knob to 'start', set the high speed fuel mixture knob to 3, engaged the choke, and pulled the string. nothing happened. kept pulling it for a few more mins and nothing happened. didn't even turn or fire once. also tried it with the fuel mixture knobs set to be very rich and also with the throttle on low and on high.
i thought it might need new spark plugs. but i tested the old ones in my push mower and they worked perfectly fine.
could the water just not be deep enough for it? i was told it can't start without being in water. all but the top 2 inches of the lower unit are in water, but it water covers all the holes etc on it.
