bigboat606
- Sep 6, 2009
- 52
I have a 1997 Mariner 15 hp that has been having starting problems when cold only. The first pull, the engines fire right up a few times - almost runs- and stops. This engine used to always start on the first pull! After that it is very difficult to start. The only way I start it is to pull the cowling and advance the throttle (a lot). When started, it runs and idles great. I have followed the manual's suggested starting procedures including priming it three or four times. I decided to pull the carburetor at which point I checked the primer pump. It shoots fuel 4 feet! - so the engine is definitely getting fuel when starting. Note I rebuilt the carburetor last year due to rough running and since have had the starting problem - but the engine runs and idles great otherwise.
I ran into a blog where another person was having the same problem as I am and it was suggested it could be an air leak between the carburetor and reed block. When I removed the carburetor I noticed a formed rubber o-ring type seal embedded into the reed block and no other gasket. The guy in the blog had the same-no gasket. But when I checked the Mercury parts catalog diagrams a gasket is shown. Also my carb rebuild kit had a gasket and no replacement molded o-ring type seal. Does anyone know if I should use a gasket between the carburetor and reed block even though there was not one on the engine originally? I bought the engine new and am the only one to have worked on it, so I'm fairly certain it did not come with one - especially since the other guy's engine had the same. And if I don't need a gasket, any ideas as to my starting problem?
