RandyJ
Master Chief Petty Officer
- Jun 13, 2002
- 808
Model 152F4A SN 1127... from what I can find out this is a 1984 engine. Before I throw away a pocket full of money on this nice looking motor I thought I'd get an opinion. It is not firing at all. The points look great. Not sure how to check a condenser. I went by the book to check the coils. When I checked the ohms between the two little wires (primary and ground) I got like .004 ohm or therabouts on both coils. My Seloc manual says I'm supposed to get between .7 and .9 ohm. When I checked between the sparkplug wire and ground I got 7 ohms rather than the 7,000 to 17,000 ohms as in the book... the same on both coils ... I find it difficult to believe that I have the exact same readings for two bad coils. The only cheap way to check is to replace the condensers for less than $20. Well, guys, how do I check the coils on this thing?
