I have a 1989 force 15 horsepower motor. when I started with the choke all the way on it runs okay but will eventually die. When I put the choke off it revs so high it sounds like it's going to blow up. the butterfly inside the car was not stuck open it works. I play with the idle screw it made no difference. Also need to know what the idle screw supposed to be set up how many turns out. Any help would be grateful thank you
