15 HP - Gear oil change
Calibra
Hi
I want to change the oil in the gear case. There are two screws, one above the other.
The heads of the screws have some damage to them, but not loads.
I am using a big screw driver, but I can't seem to release them. Any tips?
Thanks
James
Rick.
They should both be straight blade heads, there is a phillips screw you should NOT remove. Get a good purchase on the head and then apply sudden force and they should break loose. If not try a socket driver with a properly sized bit. Best of luck. Rick.
Calibra
Hi
They are two straight headed screws. Just a b*tch to undo! lol.
I'll give it another shot later this evening
Thanks
James
F_R
ANYBODY that intends to work on an outboard motor needs one of those impact screwdrivers. The bit rotates when you whack it with a hammer. The hammer blow also keeps the bit from jumping out of the slot. Works both ways, taking screws out and putting them back in. The tool will have those tight screws out before you even have time to think about it.
hardwater fisherman
I agree with what was said about the impact drivers I have one and it works great. In a pinch I also used vise grip pliers locked onto the handle of a large bladed screwdriver.
