Tpainter81
- Sep 3, 2019
- 8
1975 evinrude 15 hp. Just did a fair amount of work to this motor. Got it cheap. I put new water pump. I added a tell tail. Carb had been recently rebuilt but whoever did it forgot to install low idle jet on carb. Guy said it ran poor. I’m not sure how it even ran at all. Got it running good and noticed water leaking from thermostat cover. I replace thermostat and put new gasket on cover. I started it up and it ran good. Then noticed water dripping from bottom of motor. I increased rpms and leak got worse and motor started sputtering and died. Then it’s very hard to start up again. Several pulls and still won’t run good. Went back to it later and started up and did same all over. Water is not coming out of original hole very well either. It comes out of the tell tail very strong though and motor is running cool when it is running. So do I need to just remove powerhead and change gasket or do I have other issues? Thanks
