15 hp merc question
nlar
I just bought a 1992 15 hp. Runs great but I don't get much water coming out of the pee hole at idle, I get alittle more at trolling speed and when I give it more throttle and then wide open I get a good steady stream. I was going to change the impellar but when I went on line to get parts under the cooling system it also shows a thermostat in the parts list. Is there a thermostat on this 15 hp, if so then what it is doing is probably normal I would think.
Barnacle_Bill
Re: 15 hp merc question
If you don't know when the last time the impeller and thermostat was changed it is a good idea to change them. Its cheap insurance.
7920hpMercury
Thermostat is likely easier to change than the pump impeller. Follow the tell tale hose to the back of the engine block & 2 10mm bolts removes the cover.
If you do not have one already, a Mercury factory service manual is very useful. Check ebay or Mercury direct.
Great little motors!
