This is my first post here since I could not find my answer by searching like in the past.
I have a 1997 Merc Tracker outboard that is leaking fuel out of the carb primer bulb when the motor is running and when I prime the fuel line primer hard it leaks sometimes out of the carb primer. (I believe the part number is F681046 of the part fuel is leaking out of when running.)
If there was/is supposed to be a check valve in the carb primer then this would not happen so I don't see how replacing this part will help so please guide me.
What is causing this?
Is the carb not seated right so the fuel is getting to high in it?
Thanks in advance for all the help!
