15 hp nissan model NS15B2
teucer49
Hey guys,
Couple of questions, My Nissan seems to be running fine, it is a two cycle and want to confirm something.
When running, it spurts water, quite a bit (water cooled) to the rear. It comes in spurts, rather then a constant flow coming out. Is it normal since its a two cycle.
Also, I am having lots of trouble taken the screwws out so I can take the motor to the dealer for maintenance. Is there a trick outer then breaking the srews or cutting them off...
Thanks in advance
pwiseman
Re: 15 hp nissan model NS15B2
Try some penetrating oil on your screws and let it sit for a couple hours. If you stll can't break it free, try heating with a torch. This will cause some expansion and tends to free up nasty sticks. Don't go to crazy though.
Not a Nissan expert, but I am thinking you should replace that impeller as you normally see a constant stream.
teucer49
my motor is not starting.... everything was fine a few weeks ago and this week end a no go....
I took a good look at it and it seems that there is no fire coming at the plugs.... Any ideas, suggestions? could it be as simple as the coil.
Plugs are new, wires looks good and gas seems to get to the engine / plug no problems.
Thanks for the inputs.
pvanv
Diagnose ignition circuit. Make sure stop lanyard in installed.
