I have a 16' 65 starcraft fiberglass boat with a 15 inch transom im restoring, the motor i picked up is a 66 45HP chrysler, i will be needing to add some height to the transom because distance between where the bracket rests on the transom and the antivent plate is 23 inches, how high up should i build the transom and can anyone offer any tips on how to do this safely and efficiently? does the anti vent plate need to line up exactly with the bottom of the boat for maximum performance? will this motor have enough *** to get up and go?
