3gulls&abuoy
- Jul 21, 2003
- 5
Help! The last two seasons my saltwater series 2 has had a problem that is getting worse. Cruising along it acts like you pulled the throttle back then flares right back to speed just to pull back again. Found it wouldnt fail if i stay below 3k rpm. Also temp fixes if you turn motor off for a minute. Have ran many tanks of fuel, replaced impeller(it was overdue) tstats check good. It will act up after crossing a wake or making a turn. I bought this new (99) and havent replaced anything but impeller. Fuel pump? 02 sensor?<br />Thank you!!!
