150hp XR-4 lower crank bearing replacement
waynelk
Can anyone give me any advice as to what is involved to replace the lower crank bearing on a 1988 150hp Mercury XR-4 outboard? Looks like a ball bearing on the bottom. Not sure if I need to split the engine cases or just remove the powerhead to replace it. Any advice would be appreciated.
Dukedog
Re: 150hp XR-4 lower crank bearing replacement
Ya gotta pull tha powerhead (which ya gotta do ta split tha cases anyway), take it completely apart. Bearing is "pressed" on or off. Can be driven on or off it ya got any experience and right stuff ta do it.........
waynelk
OK. Sounds like I may be busy for a while and need to figure some way to lift the power head off without a hoist. Appreciate the response.
