handirifle
- Apr 29, 2011
- 30
Today, I was given a 1978, 15hp 20" shaft outboard, yes given
. Supposedly it runs, but I haven't been able to get anything but a "bang" out of it, twice actually. I have a 12ft sears alum boat to mount it on, but plan that, if the long shank does not work out, I will try to swap it for a short one.
Now, to list what I have done so far. There is great paperwork that came with the motor, including a service manual. There are receipts, to show the coils and condensers have been replaced ( a few years ago) as well as the plugs. The previous owner also changed out the points cam, not sure why, but it is installed correctly (letters up, and aligned with key).
Evidently, over time it has had running or starting issues, based on what has been replaced. The fellow that gave it to me said it runs (not for me) and revs freely, but stumbles under load.
I have pulled, and gaped the plugs according to manual (.030") and have pulled the flywheel, checked the keyway, and set both sets of points at .020", carefully. I tried to test the coils and condensers, but am not sure how, really. All I have is an ohm meter. I also tried to test compression, but my screw in tester's threads do not match the motor's. Are they metric?
I used new fuel, and after cleaning the connectors, I hooked them up to the tank, and the motor. Pumped the bulb, and started to pull. First thing I discovered, is the pull starter seems screwed up. It barely lets me pull 1/2 rotation before it comes to a hard stop. So to get around this, I rigged up a pull rope and would it around the top of the flywheel, where it's designed for one.
Pulling this way i get a good run on it. So after pulling and pulling, choke in and out, and in again, I finally get a loud "bang", not even sure where it came from. One thing I should mention here, is that when checking the plugs, I MIGHT have mixed up the plug wires, but I have looked the service manual over front to back and there is NO MENTION of firing order. I need to know which coil fires which cylinder. Currently, if memory serves me, the front coil, serves number 2 cylinder, at least the one marked number 2 on my motor. That is the lower cylinder on this one. Not sure if that is correct either, since the manual says NOTHING about it.
Anyway, an advice on what to do next?
Any help appreciated.
