15hp Evinrude. I NEED HELP.., please
merkdawg0084
Ok guys I have a 1993 Evinrude 15hp E15rletb. The carburetor that is on it is a late model carb, The top cover is part # 0436762 which now superseded to part # 0437985. Which is actually listed under a 1994 Evinrude. This cover has 6 mounting holes and 2 holes for the breather, total 8 holes. According to a few websites this part is NLA! Can I possibly use the cover shown in the picture below? But the carb gasket will still have the 8 holes. Thx.
Bosunsmate
You could ring a omc agent and ask
But if you think that one will fit try it, i never have but i get lucky now and again trying such things.
merkdawg0084
Oh I’m sure it will fit, but how critical is that 6th hole? Just seeing if anyone has encountered this before. Thx
Newyota
I could be mistaken, but I thought a another hole could be drilled and tapped on those earlier models like yours to help with the sealing of the top?
just_james
I’d drill a 7/32” hole, centered on area I marked. They are the same, but they don’t drill the 6th hole in it. You can see it’s marked for it.
merkdawg0084
Exactly just_james I’m thinking the same thing. Just not sure how the underside is cut out for the gasket? I actually found a top cover with the superseded # in GA. and Wisconsin. My motor is a 93, but it is a late 93. So it has a 94 carb on it..
just_james
Are you positive it’s a ‘94 carb? Gaskets are different between years. Different idle circuit. Left is 93, right is 94.
merkdawg0084
Yessir it is a 1994 carb. I do have the gasket on the right. And my top cover matches up to that. It has the 8 holes. That’s why I couldn’t use a 7 hole cover and drill out the #6 hole. The gasket wouldn’t match the cover. I think I might have fixed the problem. The problem that I am having is that the motor is hard to start and won’t idle, I think I had a cheap aftermarket gasket on top that was covering up some passage ways. Put a new gasket ion today. Will try to start again soon, Thx,, I’ll keep ya posted..
werewolf
i found a place to buy those tops , and if the idle bleed holes are stopped up it wont idle and will be hard start, i have a 91 electric/pull and had a oring piece covering those three holes and didnt want to start one day,
merkdawg0084
Cool. You and I have different part numbers, but I was able to find a couple myself. I bought both of them, lol
merkdawg0084
