15hp force high speed
Rex Birt
I have a 15 hp force motor and seen on here another had close to the same problem. But what my motor is doing is when I put it in gear and take off it will run ok tell about half throttle or so and then it revs and slows. The prop seems to quite turning. Slow it down and start over and the same thing happens. my question is where the prop is put together can that be seperating. I mean on the prop itself where the inter and outer part of the prop is put together. Or are we looking in farther to where the 90 degree is on the lower shaff.
JB
Re: 15hp force high speed
Howdy, Catfish.<br /><br />You have described a "spun" prop, and you have figured out exactly what is happening.<br /><br />A prop shop can rehub your prop. If you don't have a spare to use while you wait for the repair, get one now and keep it aboard.<br /><br />Good luck. :)
Rex Birt
adminal of the High Sea; Thank you very much and yes I think I will get a new one and use this one for a spare. Just got on this board and got a quick responce. That I realy like and I also gave one. will probably look on here alot and if I can help someone that would be great. And I think the rest of that quote is ( Is a sailors delight )lol<br /><br /> :cool: Catfish156123
Rex Birt
I just realized that I should have addressed you as JB Thank you again<br /><br /> :) catfish156123
