15hp gamefisher leaking gear oil from water intake
jpatz18
Well i took my boat and motor out for the first time since i bought it no leaks! But my motor seems to have problems. Running fine shuts of after about 15 mins. i have determined i need a new impeller i think that whats its called so it wont over heat.
this isnt my exact motor but i have 2 hole between a & b when i left the moter out of the water water drains out and so does some of the gear oil. My model number is 255.581506 PLEASE HELP.
bluebrownie
Re: 15hp gamefisher leaking gear oil from water intake
do you have any mechanical knowledge? if yes, certainly you can take a look at some of the possibilities...seals gaskets etc.. otherwise, bring it to a professional.... i have a 1996 15hp gamefisher...thing runs like a top....reliable etc...but i have takent the extra measures to maintain it as much as i can..... don't take a chance with burning your motor up...bring it to a marine repair....you could post on craigslist in your area to find a mechanic that can take a look at it for a bit cheaper...those 15hp are not all that complicated to work on.... small engine repair shops may take on the job too....
foodfisher
Stop leaks in the "other outboard brands" forum
