When I start up the motor, I have to maintain at least 1/2 choke to keep it running until is warms up. Once it warms up, it will still sometimes die out after fully opening the choke and I either have to add throttle to go to a fast idle or go back to 1/2 choke.
When I also put in in gear and ease the throttle up, it will die. All of this is with the boat out of the water using ear muffs.
Is this a fuel issue or a carb issue?
Last season, the engine died due to overheating. The cause of the overheat was due to me not realizing the motor was not locked in the full down position and rather sitting at the shallow setting and I was trying to plane out. Could this have caused any damage? The engine was serviced with a new fuel pump and carb rebuild prior to the season starting.
