15hp Montgomery Ward 52124 questions!
GreenHornet763
We acquired this motor for our wedding gift. It was stored outside for 7+years without any maintance or start ups. I recently took it for a tune up to a local enthusiast of chrylser outboard motors. He put the right plugs in (l86c champions), before it had some 35hp johnson plugs in. After tune up, we took her out on the lake, ran great! After about 15 minutes it overheated. After about 2 weeks, i had time to research and pulled the lower unit. Quite amazing what i found :facepalm:, attached below. I also checked the plugs, the gaps for plug #1 was 27, #2 was 32.
Chrysler/ Montgomery ward model vwb 52124
Questions
-are the L86c the right plugs for this motor
-what are the gaps suppose to be at
-where can i buy a water pump kit
BTW, this is my first outboard motor. I'm pretty machancially incline as i fix all my cars but outboard motors are foreign to me. Seems to be very easy to operate so far.
https://picasaweb.google.com/lh/photo/zjxOTbjScB_bl8JOtf0LwGY61XB4Ix8AlGOCCYU0pUQ?feat=directlink
Robert D
Re: 15hp Montgomery Ward 52124 questions!
You're on the right track. Look for a serial number & model number on the engine. If there's no plate attached anywhere, look for any small stickers on teh engine with a series of letters and/or numbers.....it will likely be the engine model number. That impeller is way gone. Drain all the old gear lube in the lower unit and replace after assembling everything.
Robert D
What I come up with is that it is a 1964 to 1986 Chrysler built engine, marketed under the namne 'Sea King' and sold by Montgomery Wards.
I've narrowed it down with the serial/model number exactly....to:
VWB52124 15hp 2cylinder Made by US Marine (Force) Has to be a 1985 model.
That should get you started :)
Robert D
GreenHornet763
Thanks for all the research and info Robert D. Greatly appreciated
