16 amp reg/rec install
mike6868
I'm installing a new style reg/rec on my v-200. The blk,gray and yellow wires are ez. I have two red wires.... i'm not sure what the smaller red sense wire is used for. not sure if I just need to cap and stow?
tommarvin
Ensign
Some questions,
Why are you installing a new style reg/rec? Did the old reg/rec burn up,if so it could be the stator or something else burned it up.
Is it a regulated rectifer upgrade from cdi electronics, Like on our Force 125hp.
CDI showes you how to install all there ignition parts
Dukedog
anything "red" is a constant 12v positive............ put both under tha batt. positive on tha start solenoid....
