16 gauge to 18 gauge wire?
bprender
I just wired my bow light. I bought 16 gauge wire to go from my electric distribution panel to the light. I looked at the light, however, and teh factory has 18 gauge wire coming from the light itselft. If I connect these two wires, will there be a problem in the long run? Right now, the light turns on, but I don't want to burn out a 30 dollar light. <br /><br />Thanks guys.
Dunaruna
Re: 16 gauge to 18 gauge wire?
No problems, <br /><br />The longer the wire run, the thicker the wire. You did the right thing by using 16 from the panel.<br /><br />A short piece of 18 at the light won't cause a problem.<br /><br />All fused and CRIMPED ;) , yeah?<br /><br />Aldo
bprender
Also, I ran a 10 gauge from the battery to the distribution panel. Was that right?
Dunaruna
it depends on what will be drawing from the distribution panel, but 10 is what I have, a bit heavy but better safe than sorry. Gotta use the same on the return journey also (ground).<br /><br />BTW, I know, most of the time, that everyone says "start a new post for a new subject", but in your case you can ask all your electrical questions in one thread - they are related.<br /><br />Aldo
Realgun
Heck I used 6 guage wire! But then everything is run from that panel at 3% drop not 10%.
