Re: 165 Merc engine swap???
Hello Jeff,<br /> I have spent a great amount of time working on the old 165 merc. Good engine with lots of torque. First to determine if you have a bad exhaust manifold, it will leak water into the exhaust and you will suck water in on the exhaust stroke and get on the pistons. This water is forced into the oil. Run a compression check, all plugs out. Should run @ 105 +/- 10, if close then hook up hose to the muffs, take the hose of going to the exhaust manifold and let it empty into the hull(have drain plug open)and run engine(after putting in fresh oil and filter). Should stay clear,only run for about 10 min at a time like this to keep from getting the exhaust bellows to hot. 9 out of 10 it will be a bad exhaust manifold. replace it and the Riser. Probably need new exhaust bellows to, usually only get ruffly 4-6 years on one. About the 292 it will not enter change. And if it did it is not worth the trouble. Watch turning that old 250 up to max rpm's for long periods it will not take it. I liked to cruise at no more that 3000 rpms. If it turns out to be the head find an auto head in junk yard, put in new stelite valve seats and brass freeze plugs. Loper
