Donald Propst
- Jul 2, 2009
- 3
just acquired a 16 ft pontoon with 40 hp force(cheap) Currently has a 121/2 x 8 pitch prop. The prop apparently is a solid hub, thru hub exhaust. The prop is acting as if it is a slipping hub or caviation. Am thinking cavitation due to the 8 p prop. Anyone with similar setup and a prop recommendation. You can get everything from a 8 pitch to a 17 pitch. Thanks for replies. Don
