17' Arrow Glass.
Drowned Rat
Hi guys. I am thinking of buying a used 17' Arrow Glass tri hull bow rider. The boat has a 1979 model 50hp Johnson and although I have not checked the motor out yet, they tell me it runs fine. The motor looks to be in good shape. I'll check the L/U, compression, spark, etc... before I buy. The hull appears to be in excellent shape. Owner is asking $1500. This includes a trailer with new tires and winch. No electronics are included and the throttle cable will need replacing. What do you guys think of this setup? Is it grossly underpowered? The capacity plate says 70hp max. Anyone know the track record of 1979 model OMC 50hp motors? Thanks for your help, I appreciate any input.<br /><br />The Rat.
Drowned Rat
Re: 17' Arrow Glass.
Help, I'm going to look at this boat tomorrow!<br /><br />Thanks.
Bayrider
Hi Rat. <br /> They may tell you the boat runs fine but the only way to know is to have a test run.That will answer a lot of your questions :confused:
sundog
Rat~<br />sounds a little on the undeerpowered side to me, but Im sure it will run and plane, just not overly fast. may be a little slow out of the hole. <br /><br />the boat sounds like a pretty god deal if everything checks out, though. If you look online Ill bet youll be hard pressed to find the motor alone for under $800. make sure to have the motor checked out, float the boat and check for leaks (take it for a spin if you can), and double check the transom and floorbaords for rot. I bought a 1964 16' evinrude boat with trailor and 1978 merc 115 for $800, but had to put in a lot of work on the boat. Im at about $1600 now and I just got it working, with no cosmetics.<br /><br />good luck
surftrish
Hi Rat - <br />I've owned a 1976 16' Arrow Glass w/ 50 hp o/b (1983 Johnson) for the last 3 years. I actually just sold it last week for $1800. Tri-hull just as you described. It was a good starter boat for me and got me around just fine in the inter-coastal of the Gulf. I don't think that it was underpowered at all. I did have a lot of trouble with the motor (had powerhead rebuilt twice) but I think I just got a lemon. My new boat (23' wac) has an OMC o/b on it. I think what you're describing is a decent deal. Cable are not much and I replaced mine on my own last year. Good Luck!
Billnicole
its to underpowered stay away I had one with a 115 on it and that was good
