175 Johnson
Billnicole
I am looking a 19 foot grady with a 1986 175 Johnson motor. Is there anything I sould be aware of or look for? Is this a good motor? <br /><br />Thanks Bill
JB
Re: 175 Johnson
Moving to General Outboard.
james roach
Re: 175 Johnson
As long as everything checks out mechanically, this will be a great motor. If the electrical components have not been replaced, you can expect to (stator,powerpack, coils). They are simple motors therefore easy to work on.
bernieb
Re: 175 Johnson
You may consider to spend the money for a compression check ,either you check it or a dealer,while your at it check lower unit for water.
